Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
2171 Vragen Bekijk alle
Removing the Heat shields from the board
I am currently removing the heat shields from an iphone 6s to perform liquid damage cleanup. I am having trouble removing the larger heat shield that is right next to the battery connector. I have already mixed low melting solder with the solder that is holding the shield down, but I am still not able to get it to break free.
Any tips or help on how to remove this shield without causing damage to the board would be appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Use a hot air gun.
Normally i use a hot air gun. 250 degrees C
hold the hot air gun vertically above the board. point it on the shield and do like a circular motion on top of it. after you do that for a bit use a tweezer and try to take the shield off every few secs. hope this helps
Was dit antwoord nuttig?
Voeg je antwoord toe
Elliot zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 140
