Ga door naar hoofdinhoud
The Mac mini family was first introduced in January of 2005.
1241 Vragen Bekijk alle
red light in earphone slot
just want to know if theres anyone who solve to fix the red light in earphone slot?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sterlings answer will work but not because of cleaning it out.
It means your digital audio out has switched on. You can insert a plastic toothpick in the hole and try and switch it off. The switch should be at the 3 o'clock position and go towards the 6 o'clock position. Some people also have had luck inserting their headphone jack and pulling out a few times. Another recent report was that inserting the headphone jack and turning it in the hole helped.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
This has to do with the mac thinking there's an optical audio cable plugged in. I've had this problem many times with my macbook. I ended up fixing it by taking a toothpick and cleaning it out.
Score 2
1 Opmerking:
Voeg je antwoord toe
andrea zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,642
