Ga door naar hoofdinhoud
Professionele actioncam van Vivitar. 720p videoresolutie en 5,1 MP camera. Te herkennen aan de Vivitar-modelnummers DVR781-SIL en DVR781-BLU.
Why won't my screen turn on?
I charged the battery on my camera, but when I press the power button nothing happens. Is my battery damaged?
Is dit een goede vraag?
Score 3
1 Opmerking
Put pressure on the battery, I’m putting pressure and the screen now turns on. Maybe put something between the battery cover and the battery.
door
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
If the battery isn't the problem and you're sure the camera is turning on, check the ribbon cable between the screen and the motherboard and the screen itself. Unfortunately, both of these require opening the case. Be careful, and good luck!
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
i have the same problem
door
mine turns on but it has a triangle warning sign and stays stuck like that
door
i think my wire cut and i repair it but not turning on
so pls tell me how to join the wire together
door
Het nuttigste antwoord
I'll suggest examining both the battery and flash card door making sure they are in contact. If that doesn't fix it, I'll buy new batteries and see what happens. And if after all these, this problem still exists, then the problem is likely to be internal to the camera.
Score 2
I just bought this camera put it on the charger and it will not charge?
Light comes on and can be turned on plugged in, but once unplugged it will not tun on...
2 opmerkingen:
same thing for me but i used mine once and it dosnt work
door
I have the same problem used it once and now nothing blue light comes when pluged in but will not power up
door
Voeg je antwoord toe
Jordan Baum zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 10,720
