Washing machine pouring water continuesly
Hello..I am using fully automatic top load washing machine Panasonic NA-F70B2 ...yesterday it suddenly had a blast after few minutes of cycle started...I saw lil smoke and smell coming out of it...i call a repairman...he replaced the inlet valve and the fuse...then i turned it on and the water started immediately even before i adjusted any program...and won't stop while overflowing... then he replaced the pressure switch... but the problem remains..he is saying the main control panel is gone...but everything else is working fine other than the water supply problem...can it really be the control panel?
Is dit een goede vraag?
2 opmerkingen
@msuns can you add a couple of images of your control board and the area where you think the smell is strongest? Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that. Also, what exact model is your washer?
door oldturkey03
@oldturkey03 I added the photos...the model of my washing machine is Panasonic NA-F70B2...There was a strong smell in the inlet valve which I replaces...but the is still burnt smell in the white port in the picture...
door Nusrat Jahan
