Keyboard wont connect to tablet
Keyboard will not work after I connect it to my tablet
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 3
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3 Antwoorden
Gekozen oplossing
The HDMI port must be enabled for the keyboard to work. Go to display and check HDMI.
Was dit antwoord nuttig?
Score 6
Commentaar:
Thanks, that did the trick!
door
That worked. Glad to see an expert that actually knows what he's talking about. Thank you!
door
Thanks for the hdmi info. Learn something new every day:-)
door
Thank you so much! I've been without a keyboard for over a year now. Rca sent me several replacements; some worked for a short while, some didn't work at all. Your solution did it! You are my hero!
door
I have the same problems but i went to display and im not seeing anything that says hdmi
door
1 commentaar meer tonen
you may need to reinstall the drivers or check the docking port to make sure the docks are both clean and have no lint as this has been an issue with this 2 in 1. hope this helps
Score 2
Commentaar:
How do I reinstall the drivers. I bought a different keyboard cause mine quit working, now the new one won't work......Help......
door
Trouble shoot and reconnect the keyboard.
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 6
Afgelopen 7 Dagen: 40
Afgelopen 30 Dagen: 202
Altijd: 6,669
