Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
576 Vragen Bekijk alle
Galaxy S5 G900 display works on Galaxy S5 New Edition?
I need to know if the Galaxy S5 G900 display are the same or can work with my S5 New Edition. Don't exist specifically "S5 New Edition display" in my country, and don't worth for me to bring it from another country.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
There appear to be some small differences in shape and ID tags on the flex cables.
Good new is to be safe you can find the Neo versions on ebay and other sources;
http://www.ebay.com/itm/like/18204441381...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
The dollar exchange is really prohibitive. Cost 60% of a new one and it takes more than 2 months to deliver in my home. Thanks for the help.
door
https://budgetelectronics.ca/product-des...
Budget Electronics is Canadian distributor that the company I work for uses. They're great to work with. If they don't have an item listed that you're looking for, you can contact them and they will find it! They procured the S5 Neo LCD + Digi for me when I ordered a standard S5 from them when I assumed an S5 would be compatible.
door
Het nuttigste antwoord
Hi,
Here is a link which shows the model numbers for all 42 Galaxy S5 models. With this you may be able to find out if the G900? display is compatible with your S5 New Edition (also known as Neo).
Hopefully this is of some help.
http://androidforums.com/threads/42-gala...
Score 2
1 Opmerking:
The model is G903M. The available display is G900H or G900F.
door
I currently have an S5 Neo I'm attempting to repair. I could only get my hands on S5 LCD + digis. I'm attempting the repair but the connector cables are slightly different. I fear forcing it may damage. So my guess is that they are not compatible? Any confirmations?
Score 1
1 Opmerking:
Confirmed myself that a Samsung Galaxy S5 LCD + Digitizer does not work with a Samsung Galaxy S5 Neo. The connectors are slightly different. The glass and the digitizer are the right size, but the connectors are different. Keep that in mind when looking for parts.
door
Greetings i ordered a G903F lcd & digitizer on ebay for my G903M which the spec are the same but yet still it did not work, no display.
Score 1
Could you gather more information on this Russo? I've got the same problem right now. My S5 neo needs a new display and i can only get my hands on a S5 display atm.
1 Opmerking:
I asked to some sellers and the answers are not satisfatory: Some say that works, and some don't. I really don't trust in local technicians or sellers, here in Brazil they just don't know what are doing in most cases.
door
How about the connectors? The connector from the broken screen of S5 New Edition Duos SM-G903/ds in the assembly of the S5 Neo G903F? Would it work? I'm living the same problem! And I have already bought two screens!
Voeg je antwoord toe
Russo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 7,345
