Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
New SSD, clean OS, yet SUPER slow, now it won't boot.
So my Mac crapped out on me back in November, I took it in and got my data recovered and put on a 1TB ssd external. The tech suggested that I may have had a bad HDD and to replace it with a samsung 850 pro SSD.
So I finally got the money to do it and bought 2 850 pros, one for my macbook and one for my GF. I did the transfer using CCC and my girlfriends works great, super fast, fantastic. Mine has been a pain. I tried putting a clone of her system on the drive and booting up that way, super slow. So I erased it, installed mountain lion and rebooted. Still unbearably slow.
I ran AHT, came back with no trouble detected. I reset the SMC, the NVRAM, and you guessed it still unbelievably slow. So I went to verify disk, results were clean. Next verify permissions, lots of issues, so next stop repair permissions. Permissions repaired, and now here we are, the machine won't boot up, I get to look at the apple logo, no spinning wheel, just the apple logo, for about 5 minutes until it decides to restart and try again, to no avail. So now I've got myself a very expensive paper weight and no idea what to do.
Please send help.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
First you'll need to check your systems firmware. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. Make sure its at least at the level shown in the T/N, you may have something newer which is OK.
Make sure you are booting the system up internally with your original HD or using an external connection with either the old HD or your new SSD. Once upgraded if needed go into the system profile to check the SATA ports data rate. It should be SATA III (6.0 Gb/s).
I suspect your old drive was only a SATA II (3.0 Gb/s) drive (the original Apple drives were only SATA II in many in this series).
What happens here it the data flow is too fast for your original cable to handle running at the higher data rate. Thats why the HD works (SATA II) and the SSD fails (SATA III).
You need a new SATA cable as your system came with a SATA II cable. Here's the correct cable: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Afbeelding
Product
$34.99
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thanks, I will give that a try once OS X is done re-reinstalling. After updating permissions I could not get it to boot regularly so I re-ran the AHT extended to verify hardware, still clean. The installation has been running for 8 hours, and has 86 HOURS remaining...
door
Replace the cable first!
door
@mayer Is it safe to stop the reinstall?
also I did the same SSD transfer on my GF's mac and it works great, same year and everything, no cable replacement required, do you think it could be something else?
door
Everthing was up to date, so I tried booting with the SSD plunged into my data transfer cable using the option boot and through that everything is working wonderfully, thank you so much. The cable will be here on Tuesday!
door
Did you try a PRAM reset?
https://support.apple.com/kb/PH18761?loc...
Does it let you go to the recovery HD partition?
2 opmerkingen:
yes PRAM and NVRAM reset procedures are identical.
door
Yes It lets me go int the recovery, Im trying to re-reinstal OS X and its been going for 8 hours, the download bar is about a 1/4 of the way complete with an estimated time of 86 hrs and 10 min -___-
door
Hi I have a MacBook Pro 2011. Which cable do you recommend?
1 Opmerking:
Same one ;-} The 2012 is a better version of the same cable.
I would also add a strip of electricians tape on the uppercase were the cable rests to help protect it from the rough aluminum surface. Also don't over fold the corners as that fatigues the foil wires in the cable.
door
Voeg je antwoord toe
Alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 6,090
