This nifty little trick has stopped all iTunes Error messages dead in their tracks. Give it a try. It worked for me after two days of trying to restore a phone in recovery mode.
Step 1. On your Mac, go to your āApplicationsā folder.
Step 2. Now navigate to the āUtilitiesā folder.
Step 3. Launch "Terminal".
Step 4. Type "sudo nano /etc/hosts" (without quotes) and hit return.
Step 5. Enter your password
Step 6. Use the down arrow key to find the āgs.apple.comā entries. Once the cursor is in front, make sure you comment out the line(s) by entering ā#ā in front of the text.
Step 7. Save the file by pressing CONTROL+O.
Step 8. Exit the nano editor by pressing CONTROL+X. I found ctrl X didn't exit for me, so Try "return' key after Control O to save and exit.
Step 9. Restore your iDevice.
Windows:
Step 1. Start ā> Programs ā> Accessories
Step 2. Run Notepad or WordPad
Step 3. Click āOpen..ā from File menu.
Step 4. Browse to Windows/System32/drivers/etc
Step 5. In "files of type:" select all documents
Step 6. Open "hosts"
Step 7. Delete all line that has "gs.apple.com" or something like that
Step 8. Hit Save
Step 9. Restore your device
1 Opmerking
I had this problem on my 4S. Original battery APN 616-0579. Bought a replacement battery APN 616-0580 (said was compatible, couldn't find a way to order a specific APN). Worked fine until I tried to upgrade the iOS version, then got persistent errors (error 29 on restore). Put back in old battery, and the iOS update went fine.
So every time I have to update iOS, I have to swap batteries, and then swap back. What a pain. I wish they would not claim multiple APN #s are compatible because they are not, they should have this info where they sell batteries and let you order a specific APN #.
door dovo329
