Ga door naar hoofdinhoud
HP ProBook 4320t manufactured in May of 2010.
6 Vragen Bekijk alle
Can't remove CPU heatsink because two of the screw heads are damaged
I replaced the thermal paste on the CPU and Radeon chip in a 4320s a couple years ago due to over heating causing shutdown on boot which fixed the issue.
It's happening again but this time I can't remove the heat sink because two of the screws holding it in place are damaged and won't turn no matter what screwdriver I try. The driver just spins in the head of the screw.
Any advice would be greatly appreciated.
Thanks in advance!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Have you tried these:http://www.amazon.com/Alden-8440P-Grabit...
Or use a round disc bit to carefully grind a line in the screw with a dremel so the screwdriver will grip?
Was dit antwoord nuttig?
Voeg je antwoord toe
Zayn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 543
