Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
1039 Vragen Bekijk alle
Just fixed my iPod now it won't work
I took my ipod apart to fix the LCD screen brand new from your site. When I reconnected it there was a back light but no screen but my computer recognized the ipod.
I double checked the connections and tried again now I have no sound, no screen, and my computer can't tell the ipod is even there. I can't even get the old screen to run. Anyone run into a similar problem.
The battery is new and so is the lcd screen.
Update (01/21/2016)
I'm missing the clip that locks down the ribbon for the LCD screen. I'm currently looking for the right type of connector on the DigiKey site so I can replace the clip. If anyone knows where I can find the connector that would solve all my problems. I definitely don't want to spend 100 dollars on a replacement motherboard and I'm hoping to avoid buying a replacement ipod.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
A white screen is usually that the LCD ribbon isn't inserted or not making a good contact.
Was dit antwoord nuttig?
Score 1
Have you check the voltage of the battery with a multimeter, and you also checked the pcb for broken or burnt components.
Voeg je antwoord toe
Peter Gadoury zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 76
