My PS3 doesn't turn on.
I attempted to do an update to my PS3 and it failed the update 2 times so I thought that I would power cycle it to see if it would finally work.
When I power cycled it I flipped the power button on the back off and pulled the power cord out for 20 seconds. When I turned the device back on the red light on the front came on showing that it has power.
I pressed the on/off button on the front of the PS3 and then the green light came on showing that it was booting up, but the green light only stayed on for 10-20 seconds then it immediately went back to red.
I can't really hear anything turning on in that 20 seconds that the green light is on and am wondering what went bad? Does anybody have any suggestions to help me find a solution?
Can I pull out the hard drive and re-format it and put it back in to see if the file system was bad?
Any suggestions would be super helpful!
Thanks!
Is dit een goede vraag?
1 Opmerking
So it appears that it isn't hard drive related and I can't do a system update. When I click on any of the options in safe mode the PS3 will either just shut off or when I try to restore the file system it says an error #8001002b. I can plug the PS3 hard drive into my computer no problem, so I formatted it as suggested on some forums and still no luck.
Any more ideas?
door bankg3
