Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 locked after screen replacement
iPhone 6 locked after screen replacement. Message appears to connect to iTunes. When connecting to iTunes message on iTunes appears to unlock the iPhone with code. An endless loop.
Maybe an Apple lock when detecting an unoriginal screen? Don't know.
Please help. Thanks
Is dit een goede vraag?
Score 8
1 Opmerking
is this still the case with changing the 6 screen?
i am just about to change one for a friend?
door
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
Do the following ONLY IF ALL the following conditions are met:
You are sure that the device does not have Find my iPhone enabled, or you or the owner knows the Apple ID and password.
You have the original Touch ID subsystem (Home button assembly) on the phone and intact.
You are sure that the device was backed up to iCloud or iTunes before, or you don't care about the content on the phone.
Then,
Plug in the cable, turn off the device, press power + home button for 8 seconds, then release the power button but hold the home button until the device is recognised by iTunes.
Was dit antwoord nuttig?
Score 11
12 opmerkingen:
Tom, thanks. Worked out just perfect :-)
door
atta boy Tom. you for real my dog.
door
Amazing thanks... copied it to the letter and worked perfectly thank you
door
I keep getting an 0xE8000015 unknown error everytime the phone connects to itunes. When I hold the buttons i only get the apple logo and then it blinks. help i dont want to have to spend another 150 to send it back to apple
door
not all heroes wear capes but you need one!
door
7 commentaren meer tonen
Hello,
I'm not sure how this could happen to you. Best it to restore iPhone via iTunes. Basicliy if you cant enter passcode somehow, enter it! If u cant, restore it or put new iOS via DFU or Recovery mode.
Hope it helps, Nikola
3 opmerkingen:
Hi Nikola,
thank you for your answer. I can't enter passcode on the phone. The only screen is the emergency call, and a message "connect to iTunes". Then when I connect to iTunes I get the message "Enter passcode on iPhone to unlock". Not able to get into to the restore menu.
What is DFU?
door
Why u cant enter passcode? ur touch doesnt work?
DFU mode is Device Firmware Update, its used in case u cant boot properly device or if u need downgrade iOS
door
The phone is already disabled by too many failed passcode attempts at this point, recovery or DFU is the only way out.
door
iphone passcode unlock. You can remove the passcode by restoring your device from iTunes or Find My iPhone if you've turned it on before. The catch here is that you will lose your data by following the above method, so you should be aware of that.
I did tried and it's work well
1 Opmerking:
I have unlocked iPhone 6s plus after getting it from USA to India, one day screen was broken ,so I replaced it OEM brand display, after a day my phone got locked and it is asking activation is required, Any help can be appreciated
door
I keep getting error (9) what dose that mean when it's restoring
I have the same problem before and the Joyoshare iPasscode Unlocker fix it, so maybe you can have a try, it’s helpful and safe.
Voeg je antwoord toe
larsthue zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 30,111
