Can an iMac have a dual SSD?
Hi hi at all,
I have a iMac with fusion drive, my question is, can I replace the HDD for a SSD? i.e. can the iMac have two SSD?
Thank you.
Update (01/14/2016)
Thanks, but, to add the SSD sata for de HDD, have I to break the fusion drive (SSD pcie)? two SSD (SSD sata and SSD pcie of the fusion drive) can be in a Imac or not?
Is that break the SSD of fusion drive is much more difficult that only change the SSD for the HDD.
Is dit een goede vraag?
1 Opmerking
Correct! You will need to break the Fusion Drive set and leave the SSD drives independent. Which is also a good reason to go with the external solution. You can not have a dual SSD Fusion Drive set. A dual SSD would confuse the OS which is why it won't work.
door Dan
