Ga door naar hoofdinhoud
Het Bose 3-2-1 Home Entertainment System is een serie op dvd gebaseerde thuismedia-systemen in de Bose 2.1 home theater-lijn. Het Bose 3-2-1 Home Entertainment System werd tussen 2001 en 2006 verkocht en was verkrijgbaar in de kleuren zwart en grafiet.
91 Vragen Bekijk alle
No sound output from Bose 3-2-1 Base AccustiMass Module.
My 3-2-1 Bose AccustiMass Base Module no longer emits any sound. The LH and RH speakers operate properly. Input selections AUX, CD/DVD, VIDEO 1 and VIDEO 2 are also OK?
How can I troubleshoot and repair. Also, a schematic and parts list of the module circuit board would help.
Is dit een goede vraag?
Score 4
4 opmerkingen:
Need two screws one broken to go in to back of media centre for 321 Bose series 0330 19350100158AS . The small screws that the lead plugs in to.
door
Ps321 no sound but its light up green . What should I do I tried the unplug plug in dint work. looked at fuse it’s good. Help
door
My RH speaker is no sound output
door
My home theatre bass are damage
door
Voeg een opmerking toe
2 Antwoorden
Hi,
Have you tried the following two reset options:
Turn the media center off for 10 seconds, then on again, to restore communication between the media center and the speakers.
Unplug the Acoustimass module power cord from the outlet for a minute, then reconnect it. This allows the unit to reset itself.
Was dit antwoord nuttig?
1 Opmerking:
Jayeff, thanks for your quick reply. I already tried the (2) options suggested prior to submitting my inquiry. There was no change or improvement. The base AcoustiMass module still doesn't provide any output whatsoever. Any other suggestions.
door
have you checked if the tranformer in the base module have a voltage output
seems like a common problem
Voeg je antwoord toe
Louis Repassy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 73
Altijd: 14,875
