Ga door naar hoofdinhoud
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 Vragen Bekijk alle
How can I swap the battery of my psp go?
How can I swap the old battery in my psp go for a new battery and where can I find it?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You can use this guide to get to the battery, though you will have to open the device to get to it. Here is the replacement part.
Was dit antwoord nuttig?
Score 3
Use the guide (Chris Green) suggested, if you have a old PS3 controller the PSPgo uses the same battery as the PS3 controllers, you can replace the battery with that one if you cant get a replacement.
2 opmerkingen:
NO you CANNOT use a ps3 controller battery in a PSP GO. I know this because I just tried it, not only is the size different (won't fit in psp go), the CONNECTOR is different!
door
Well that solves everything.
door
Voeg je antwoord toe
Daniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 4,205
