Ga door naar hoofdinhoud
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Vragen Bekijk alle
MacBook air will not charge after small spill, everything else works.
After a small spill my macbook air would not accept a charge, but everything else worked great. I tried another charger, but same results. I plan to open the mac and clean any visible corrosion. The spill was on the keyboard and none got into the charging port. What would be the most likely area to be the problem.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If it powers up from the keyboard and all the keys work, I would replace the I/O board: MacBook Air 13" Mid 2013 I/O Board Replacement
Was dit antwoord nuttig?
Score 2
Only opening and properly cleaning the mac will be the 1st best solution. If a good cleanup does not resolve the problem you'll need find a apple motherboard repair shop capable of repairing circuits in the board if your are unable to diagnose and or smd rework soldering.
Score 1
Voeg je antwoord toe
vintagemr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 123
