spacebar doesn't work not
spacebar stopped working. no spills, not a hardware issue. when spacebar is pressed spotlight comes up this happens without the command spacebar being pressed.
Is dit een goede vraag?
Check your command key. It is possible that something is pushing down on the button in between the key. If not then check your Bluetooth settings and replace the batteries of the keyboard to see if that may be a problem. If possible try using another keyboard and see if it gives you a problem with the space-bar, if so then it could be a software setting, maybe in accessibility settings. Hope this helps!
Was dit antwoord nuttig?
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 35
Altijd: 6,595
