Ga door naar hoofdinhoud
Not booting up after HDD install
hey guys so I made a horrific mistake somewhere by attempting to add a HD on my iMac.. I had ordered the wrong SATA power cable and so put the machine back together , and only left out the optical drive out, which has never really worked properly since I got it.. Anyway put the thing back together and now I've got nothing. No screen, no chime, nothing. Just fans spinning very loudly, and LED lights 1 and 2 lit on the motherboard. Strange thing is I had messed up the data cable for the LCD , which is extremely fragile :( but when plugging back in the smallest wire for the LCD all power shuts off and the two LED goes off as if there is NO power at all.. So I tried my second monitorn - my tv with the mini display to HDMI and nothing either..
I'm really at my wits end with this.. I consider myself to be quite handy with electronics, I've built computers and laptops from scratch and considered this tone a straight forward affair... How wrong I was.. So my iMac is sitting no screen, just the 2 LEDs lighting up and a very loud fan..
Any help or assistance on what has happened would be greatly appreciated ...
Many thanks
Update (01/01/2016)
Tried the suggestions to no luck... Fans still spinning wildly, no display, still only two LEDs on... One thing I've just noticed, when the iMacs not powered on, there is a strange clicking noise and buzz from the power supply... Could this have been shortaged during the HDD replacement?
Also when reseating the ram I turned it on before putting them back in and I got a few beeps .. Guess that's the logic board telling me there's no ram.. And hoping by that nothing is wrong with the logic board... Argh I wished I never even bothered now!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Unplug from power. Hold the power button down for 10 seconds. Plug back into power. Attempt to turn on.
High fan RPM is usually an SMC issue.
If the first option doesn't work recheck all your cables. Then try to clear the NVRAM (Cmd+Option+P+R) before the gray screen. Should get 2 boot chimes then release. Reply back if you're still having issues after that.
Was dit antwoord nuttig?
3 opmerkingen:
Problem is I have no boot screen, the LCD data cable is worn, (terribly terribly fragile!!) so I can only go on my second monitor. But there is no grey screen, no chime, nothing. All I have is power, fans running (very loudly) no sound at all. HD seems to be working too, as I can hear it.. Just no display and just the two lights on led
door
Reseat RAM and give a try . Experience from my iMac 24" EMC:2211 tear down to T/S unable to get log in screen. Before reseat RAM I got 4 LED but after that only get 2 LED and cooling fan goes to high speed when switch it on. I need to re-rack both RAM again then press and hold power switch to reset it in order to bring back 4 LED .
door
Tried all the suggestions. Nothing seems to be working. See update.d note above.. Argh it's really driving me crazy
door
Voeg je antwoord toe
Lexx zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 96
