Hardrive or hardrive cables?
I took my iMac into the Apple Store because of the dreaded flashing file with question mark. At the Apple Store they ran diagnostic. I was told it could be the hard drive or the cables to the hard drive could be loose or need replacing.
I used fixit guides to open up my iMac (thanks for great instructions and videos) I cleaned my fans got all dust out with a soft toothbrush, however I found the hard drive cables were connected properly.
Now my dilemma, before I replace the hard drive is there a way to test it to see if it's really dead? Is it cheaper to replace cables, should I do that first? Is there a device that can tell you while you have the hard drive out if it's bad. Or, is there a way to connect it to another Mac to see if its' good?
I have a newer Mac mini with an i5 quad core. Just want to know and also need recover any data from that old HD if possible.
Thank you.
Is dit een goede vraag?
