Ga door naar hoofdinhoud
Repair guides and support for phones manufactured by Lenovo.
278 Vragen Bekijk alle
screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
Is dit een goede vraag?
Score 1
8 opmerkingen
I have the same problem for a LG Stylo 3 that was stepped on.
door
did u fix it i got the same problem and same phone
door
door
no my phone fell on the groud
door
Does this drain my battery?
door
3 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
very good answer and simple but very useful
door
This answer saved me.. thanks a lot
door
I dont have vr mode ,what to do,?
door
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
Score 1
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
You can't fix it with the apps or in the settings. You gotta repair it or simply just buy a new one🄲
Voeg je antwoord toe
Dragneel Potter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 288
Altijd: 22,019
