Ga door naar hoofdinhoud
My iMac Doesn't power on
My iMac doesn't power on - sounds like it is dead. It was in storage for over a year. worked fine before. change the pram battery but it still doesn't work.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Open it up and look at the 24 cans (capacitors) for swelling or leakage. If they are OK. press the reset and the restart buttons on the logic board and observe the diagnostic lights and tell us your results.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
one of the capacitors is blown.. if i change the one will it fix the problem?
door
If none of the others have failed you have a good shot. The definitive expert on these caps is Jim Worholic. Check out his information here: http://jimwarholic.com/2008/07/how-to-re...
door
Voeg je antwoord toe
Fernando Cozza zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 326
