Ga door naar hoofdinhoud
Reparatie- en demontagehandleidingen voor Magellan GPS-apparaten.
My Magellan GPS 9250T-LMB wont come on
I was on the road, my GPS was working. I unplugged the power cord from the car outlet. 5 minutes later, I plugged it back in, but my GPS won't come on. To check if the cord got bad, I checked another cord, but the GPS won't come on. I opened the GPS and checked the voltage of the battery. It shows 3.7 volts. Please tell me your opinion on the problem. Thank you.
Is dit een goede vraag?
Score 3
3 opmerkingen:
Hi,
Have you tried resetting your GPS?
To Reset: Slide the power switch all the way over to the left and hold for 5 seconds. Release then try to turn on your GPS
door
es i tried slide power switch to the left like you set, but it still it not come on
door
I have the same problem and the reset did not work!
The light that shows it is plugged in to power is the only thing that works at all. How can I make it come on again?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Charge your GPS overnight take a paperclip pushing the reset button hold it for 8 seconds release it hold the power button for 8 seconds then release it that should make it come back on if it does not you need to replace the battery.
Was dit antwoord nuttig?
Voeg je antwoord toe
roleg1313 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 39
Altijd: 1,624
