Ga door naar hoofdinhoud
De Xbox draadloze controller 7MN-0001, vervaardigd door Microsoft Corporation, is de meest gebruikte controller voor Xbox-spelcomputers en kan ook in combinatie met pc's worden gebruikt.
127 Vragen Bekijk alle
Vraag afgerond
My main buttons are sticky on my X 1 wireless controller.
So in a mysterious course of events, my X1 wireless controller buttons (X Y A B) stick. they have some movement, but are slow rising up after being pressed. Is there a way for me to remove the face plate so I can take an electronics cleaner to them and remove any residue?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Yes, use a spudger on the panels that cover the controller handles. This shouldnt require to much force and just work your way up to the top. After they pop off, there will be four security T8 screws visible at each corner of the handle. If you are not familiar the screwdriver requried is not a normal T8 it must have the hole in the middle to match the screws. After removing the screws, there is another hidden behind the battery. It is under the sticker which i assume will void the warranty although i am not 100% on that it just seems logical to me. After this screw is removed the back and front should come off
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 145
