Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
Vraag afgerond
What's happening to my battery?
I have replaced my iPhone 3G battery but now the battery also drains too fast and when I'm using it while charging it goes down the battery charge too.
What seems to be the problem?
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
If the phone gets physically hot while the battery is draining, there is a process in the OS that won't stop running. In my case, it was the push mail daemon which kept the cellular radio on constantly. Reloading the OS fixed the issue for me.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
what do you mean reloading the OS?rebooting or reformatting??
it don't get hot.and when its charging it takes long too fully charge the battery.
door
my battery drains fast,what do i do
1 Opmerking:
this isn't an answer,you need to start your own question (this one is from december!) Please provide as much detail of your problem in your new question
door
Score -1
1 Opmerking:
This should be a comment on Brian's answer. Please delete this and leave a comment instead.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 2,032
