Ga door naar hoofdinhoud
Product released in 2011. Portable on-ear headphones that come with a detachable audio cable with built-in remote and mic for iPhone/iPod/iPad connections, and a carrying case.
22 Vragen Bekijk alle
cant get pins out to replace headband
Hello!...I am trying to replace the headband on my boys Beats Solo HD and I cant seen to get the pins out. It appeared while looking at it on vid that they actually fell out....not mine of course!.I am patient so before i go further I thought I would see if I could get help here. All is going great accept for this problem. I would be grateful if there is a way or trick to get them out. Thanks very much in advance for reading.
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
See if this guide helps: Beats Solo HD Right Hinge Pin Repair
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
It's telling me I don't have access to this link. Is the link private ?
door
Well that's not right. Can we get some help here? @kelsea
Kelsea, are you sure you wanted this job?
door
Just made it public! @mayer I'm a ride or die iFixit-er. I'll be here for the long haul. ;-)
door
Spray the pins and hinge with some lube, then tap, fairly hard with the end of a screw driver and the pins will fall out or stick out far enough to grab with tweezers.
Don't be afraid to hit it.
Voeg je antwoord toe
done4fun zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,772
