Why are my pictures not being saved?
Pictures not being saved directly to device.
Is dit een goede vraag?
Make sure that your device has enough storage for the pictures you take. If not a memory card may need to be inserted into the camera.
Was dit antwoord nuttig?
If you pictures stop saving to your device you have two options. You can delete some pictures to create more memory space on your device, or you can insert a memory card. Using a memory card allows you to save a large amount of photos to your device. Make sure that you purchase the correct memory card for your device.
Make sure there is a memory card inserted in your device and it is compatible with your device.
The pictures are not saving on your device, because there isn't enough storage on your device to save them. Try deleting some pictures to create more room.
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 2,413
I have been using a memory card for some time but now it can not save even on the memory card.I have tried new memory cards. no change.You can see an image as you take a shot but its not saved in the device even after deleting all images in the device memory.
door desmond nyamangwende
