Ga door naar hoofdinhoud
Repair and disassembly guides for GE Microwave ovens.
door won't open when button pressed
I have a GE microwave/oven wall unit and the door doesn't open until 5-10 seconds after cooking or after pressing open button. There is no outside handle. I don't want to replace due to cost and installation in wall.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Cause 1
Open Lever
Inspect the open lever for damage. If the open lever is broken or damaged, replace it.
Parts
Cause 2
Door Spring
Inspect the door spring for damage. If the door spring is broken, replace it.
Parts
Cause 3
Door Latch
Inspect the door latch for damage. If the door latch is broken, replace it.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Our door does not open at all - so how would you be able to check for anything on the inside?
door
Ours is newly purchased and has this issue from the beginning. I have to push the button 2 or 3 times to open it when no food inside. After cooking, it is easy to open.
door
Check the latch that is inside as it might be dirty. This would cause it to open more slowly than expected. You might have a broken spring where the latch holds the door making it not move enough to release the door.
Score 1
Voeg je antwoord toe
Okcphinfan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 3,376
