Ga door naar hoofdinhoud
Released in 2012, easily identifiable by the "P774A" imprinted on the back of the tablet.
3 Vragen Bekijk alle
My P774A's screen is cracked, and unresponsive to touch.
I dropped my device on concrete and the screen is cracked. The device no longer responds to touch and I am unable to login to the device. Everything else on the device seems to be working well, although I can't really tell, because I can't access the home page.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like the best solution for both problems would be a digitizer replacement. The digitizer is the hardware that translates your touch to the device. It also provides the external screen. Replacing the digitizer would provide you with a new screen and repaired touch response. Consult our repair guide for replacement instructions.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sean McCauley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 94
