Ga door naar hoofdinhoud
Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1229 Vragen Bekijk alle
Need help identifying this capacitor
Can anyone please help me identify this capacitor on a 2012 A1278 Macbook Pro 13" (non retina), its near the LCD/LVDS connector. As you can see it has been shorted and is causing the LCD to display no picture, just back light (GPU is fine as it works through an external monitor).
Thanks in advance, any help will be greatly appreciated!
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 3
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
nickpit, it's not a capacitor. This is just to answer your question, not to diagnose your logicboard. The component is reference designator L9004 which is a 120 Ohm 1.5Amp ferrite bead, or ferrite choke, in a 0402 package. A Murata BLM15EG121SN1D will be a perfect match.
Was dit antwoord nuttig?
Score 4
Commentaar:
Thanks for the info!! Exactly what I was looking for. Do you think it appears to be shorted? The solder on one side is obviously missing and there's burn marks around it. If so would it be worth replacing? Cheers, Nick.
door
Not sure what shorted it out. The part is somewhere in the $0.20 range, so get a dozen and see what happens.
door
Voeg je antwoord toe
nickpit zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 5
Afgelopen 30 Dagen: 9
Altijd: 744
