Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Bose Soundlink Bluetooth Mobile Speaker II was originally released in September 2012 as an upgrade from the original device. It has an effective range of 30 feet and a battery life of up to 8 hours.
16 Vragen Bekijk alle
The speaker will not turn on when running off of the battery!
When the speaker isn't connected to the outlet and running of the battery, it will not turn on.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Antwoord
Gekozen oplossing
Hi,
If it works when powered from the outlet but not when running on the battery, it seems that there is a problem with the battery.
What indication do you get when you check the status of the battery?
Here is a link which describes how to check the status of your battery and what to do if battery is low. If no light shows at all the battery is completely flat or is faulty. Try charging it. If a yellow light comes on when you charge the battery, does it change to green? Allow a suitable length of time for this to occur, (Bose say up to 3 hours). If it doesn't change it is faulty and needs to be replaced.
http://worldwide.bose.com/productsupport...
If your battery is faulty here is a link which shows how to remove it.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Kevin Bailey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 207
