Charging Problem iPhone 6
I have an iPhone 6 that has a charging problem: if I replace the battery with a charged one, it works until it becomes discharged, then the battery can not charge again.
Is dit een goede vraag?
It's U2 Tristar charging ic at fault as it refuses to let a flat battery charge.
Was dit antwoord nuttig?
Thanks, how can i fix it? anywhere i can send to fix it?
Yes. You will need to look for someone that does board level micro soldering for iPhones.
Is there any resolution to this isssue? i have the same issue!
Replace the charging flex cable.
If it charges while not dead, how is it this?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 191
