How can I fix gamepad rumble / vibration motor?
My rumble feature has stopped working after my last repair (replaced the digitizer) and I can't figure out how to get to the motor.
Is dit een goede vraag?
Hey Kevin, before you confirm that a part is actually damaged, I'd recommend that you disassemble(start from step 13) then reassemble it. If it still doesn't work, try to follow what Nintendo recommends you to do. If it doesn't work after that means the rumble motor is broken and needs a replacement.
Was dit antwoord nuttig?
I've actually just finished disassembling and reassembling the gamepad - I successfully replaced the digitizer (which is not fused to the LCD as indicated in the teardown but uses a pretty weak adhesive that can be pried apart and reconnected). The rumble was working before I did this so I was hoping to find information on exactly what connection I may have missed/broken. I've also made sure the gamepad is fully charged and the rumble setting is enabled.
Power it off first and unscrew the screws behind the battery and Just Disconnect and Reconnect the battery Wii U GamePad Battery Replacement
Also make sure is not turn off go to control settings> wii u gamepad settings > Rumble On
@xterminal you're just repeating the contents of the link of what I said in my answer.
No cigar, thanks for the reply
@iApple Nope i didn't even see you posted anything here . Don't Worry about it.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,891
