Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
How can you transfer old chips onto new logic board
I was wondering after seeing tons and tons of bare logic board on ebay was how can you transfer the stuff over and/or who can do this service
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Andrew Kerobo, the amount of soldering of all components is absolutely mind boggling. Nobody will do this for you and unless you know how to microsolder, reball BGA IC's and solder LGA IC's there is absolutely no way. Since you are also talking about removing components from an old board to a new one, you would have to ensure that each part works. Consider this a non-doable task.
Was dit antwoord nuttig?
1 Opmerking:
I'm doing this myself,you need stencils lead paste ,heat gun,heat tape, microscope, flux, cleaning wick , logic board holder and so , ps you can do this only when you practice on old logic boards and getting the heat gun right so loads of practice first good luck colin
door
That's alot of work for any technician i suggest you just buy a good working board instead of risky your logic board. The point is dont bother buying that stay away from that!
Voeg je antwoord toe
Andrew Kerobo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,265
