This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
231 Vragen Bekijk alle
Zte zmax front camera not working. Tried everything.
Everything I try to switch to the front camera, it freezes for a few seconds and then says something about the camera is disabled. I've already tried a reboot and factory reset and a clear data and cache and it still doesn't work. Any suggestions?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 7
Commentaar:
Now the rear camera stopped working. It's saying disabled as well and completely kicking me out.
door
Its the SD Card!! Take the card out. Then try using the camera, take a few pictures. Then reinstall the sd. Hope that helps.
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
4 Antwoorden
Gekozen oplossing
Hi,
As you have tried most everything, I suggest that you check your warranty details and if still valid contact the manufacturer. If you are keen and the warranty period is over, here is a link which shows how to disassemble your phone. It may just be a loose camera connection
https://www.youtube.com/watch?v=RhuPnfOv...
Was dit antwoord nuttig?
Score 1
Commentaar:
It's strange earlier it was working to take a set a face lock but not a selfie. Now it's not working for either.
door
Hi,
Try gently squeezing the the phone between your thumb and forefinger where the camera lens is (i.e thumb on one side of phone, forefinger on the other) whilst having the camera app running.
The camera ribbon flex cable connection is very close to the camera itself, (2.00 minutes to 2.10 minutes into the video on the link in my answer). You may be able to see if it affects the camera operation at all.
If you can see any reactions it may be as I said a loose connection.
door
Tried this and it worked for me. Woo hoo. Thank u so much
door
Only the front camera works ..so I can only take selfie
door
Discovered this problem is the home screen app blocking access to the camera. Change the home screen UI to something Luke Asus Zen UI and the camera begins to work again. I previously tried all the other options this is the only one that works
Commentaar:
How do you do this
door
Bost mobail has been lieing to me to saying that it's your kid that did that or had a virus
Commentaar:
When im on my messenger it wont show my face or the selfie on my zte blade x wont work just keeps saying unable to connect to camera or disabled due to security policies can someone plz help me out here
Voeg je antwoord toe
Bianca Aldaco zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 7
Afgelopen 7 Dagen: 35
Afgelopen 30 Dagen: 177
Altijd: 16,376
