Why is my charger for ipad 2 gets hot?
when charging ipad 2 charging adapter gets hot.
Is dit een goede vraag?
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Chargers getting hot is normal because about 220 to 240 AC volts are converted in the charger to 5 DC volts. Chargers usually contain resistors which does it work by converting electric energy to heat energy to reduce the voltage. It also contains capacitors which also gives of heat.
Charger getting hot should not be a problem unless it happens even when the device (iPad in this case) is not connected.
Rep: 1
Connected to what? Mine is getting hot too. Is it a problem?
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 89
Altijd: 10,829
