Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Both cameras are black
My front nor rear cameras are not working after replacing phone housing when I touch on camera I just get a black screen help needed
Update (10/28/2015)
So how do I go ahead fixing that ????but if one go out y is it affecting the other camera
Is dit een goede vraag?
Score 1
2 opmerkingen
hello Maijc ,
i have the same problem, did you find any solution ??
door
I changed the back camera but it's the same thing and the camera from the damaged phone works in other phones so I came to the conclusion that main board has a fault
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Guessing one of your cameras has gone out, and it's stuck at that screen
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
hallo imedic ,
i have change the camera's but i still have the problem??
door
You changed both of them? And it's still happening? If that's the case try resetting your settings
door
“I changed the back camera but it's the same thing and the camera from the damaged phone works in other phones so I came to the conclusion that main board has a fault”
and then?
Is it the mainboard? Got the same problem here, also no flashlight.
2 opmerkingen:
Got same problem. Both cameras are black flashlight works tho.. Anyone got a fix?
door
I got a new phone as replacement. But the guy in the store said both cameras were defective.
door
Voeg je antwoord toe
Majic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 251
