Ga door naar hoofdinhoud
The third iteration of the 10.1 inch Galaxy Tab tablet.
120 Vragen Bekijk alle
WiFi Connects and drops at random
My WiFi on the Samsung Galaxy tab 3 10.1 GTP5210 will sometimes connect to a network (if at all) and then drop connectivity after a few moments. I've performed a hard reset, a factory reset, tried multiple networks. I am wondering if this might be a physical component I can replace for a WiFi antenna and if so any recommendations on doing so. My next step is to try a firmware update but I am not hopeful.
Got the tablet for free from work because of the issue so I am trying some cheaper options to fix before giving up on it.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
This is free, go to google play store, go to apps, key word "wifi analizer" select the one by farcpro. Wifi must be runing to work the app. This app tells what chanel you are on, who is on your hot spot chanel and more. I have it on all of my devices as ive been in your dark spot. I hope this helps.
Was dit antwoord nuttig?
Same issue here. Any solutions?
Voeg je antwoord toe
Tom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 4,273
