Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
My proximity sensor doesn't respond
I recently replaced a cracked touch panel/digitizer on an iphone. Everything works, the home button, speaker-everything except the proximity sensor. When you make calls, the the iPhone doesn't go blank, as it should, when you make calls. It's not responsive at all. Has anyone else had this problem?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
check cable no 3 is seated right
Was dit antwoord nuttig?
If you need to replace it (#3 ribbon), see this:
iPhone 3GS Proximity Sensor Ribbon Replacement
done, but it doesnt still work.
birghtness sensor works, but proximity nope.
Voeg je antwoord toe
AshD zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,217
