Ga door naar hoofdinhoud
The HP Pavilion g6-1b79dx is a 15.6” laptop with a pewter finish made in 2011. It has an integrated webcam and an Intel Core i3 processor.
8 Vragen Bekijk alle
Vraag afgerond
How do I replace the battery in my computer?
I think my battery is faulty so I need to replace it.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi Rachel,
You're referring to the CMOS battery (coin cell)? If so, take a look at the service manual from HP:
http://h10032.www1.hp.com/ctg/Manual/c02...
1.) get an idea of where the battery is located:
- pg. 18 -- shows the battery's relative placement within the body
- pg. 22 -- identifying description of the battery
part# 20 = CMOS battery
2.) gather your tools and prepare a suitable environment for opening up your computer:
- pg. 33
- pg. 35 (make sure you disconnect all power source to the laptop and drain whatever power trailing within the laptop, proper grounding, etc.)
3.) disassembly:
- pg. 39 -- starts here, the HP guide has nice visuals to aid you through each step leading up to the
CMOS battery exposure
-- you'll remove the battery pack(pg.40), then the service cover (pg.41), then the hard
drive (pg. 42)
  • no need to follow steps continuing on pg. 43., skip to pg. 49 to see how to replace the coin cell battery.
hope this helps!
-A
Was dit antwoord nuttig?
Het nuttigste antwoord
Hey Rachel,
The adapter may not be working properly to charge the battery. You can try a different adapter. If that does not work, the battery may be faulty. You can check out more at the device troubleshooting page.
To replace the battery, flip the device over. Find the pull tab with the battery icon and pull it. The battery should pop free and you can replace it.
Good luck!
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 770
