Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
4030 Vragen Bekijk alle
The non-magenetic screw instruction is wrong
Three times, I’ve tried to correct the non-ferrous/non-magnetic screw instructions for both the 5 and 5s.
iPhone 5s Home Button Replacement
Each time, the correction was denied by iFixit staff.
Why? It’s obvious to anyone who has fixed a 5 or 5s that the instructions are wrong, and worse, the instructions that are there on the site will damage the device and screw with the magnetometer when reassembled.
The non-magnetic screw is longer and in the upper right, not shorter or in the lower left.
Why were the corrections denied and why three times?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
3 Antwoorden
Gekozen oplossing
cs, that may have to do with you not having enough reputation points to make those changes. Looks like you will need 30,000 for that. You may have more luck contacting the ifixit staff directly on here or leave a comment/question on here. It is more frequently visited by the ifixit staff.
Was dit antwoord nuttig?
Score 1
Commentaar:
That or get to posting
door
Het nuttigste antwoord
You're right, it's wrong. I have no idea
Score 2
They're wrong about a lot of things. I just use the guides to have some idea about the internal layout, after that you're on your own.
Score 1
Voeg je antwoord toe
Drtofu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 102
