2001 Jeep Cherokee driver side door lock not working.
I recently repaired my speaker in the driver side front door of my 2001 Jeep Cherokee Sport but when I put the inside panel back on the door lock won't work. The inside lock button is stuck in the on position (but the door is not locked) and will not move and the key lock will not lock the door. If I take the panel off and disconnect the cables to the lock, the lock works per using the cables and the key also works. Its like every time I put the inside panel back on something is out of line. I know I am connecting the cables correctly as it is impossible to get them backwards. The power lock locks the other doors but not this one although I hear it working. I really think this is mechanical, not electrical. I also don't believe the cables got bent as they are pretty heavy duty. I am wondering if something happened to the levers where the cable connects to door. I did the same thing to passenger door, while trying to fix that speaker, but everything went back together without a hitch.
Is dit een goede vraag?
1 Opmerking
did you ever get this fixed? and how?
door napelella
