Photo's and all screens look like Negative's
All my screens look like a negative
Is dit een goede vraag?
Mine is looking inverted too and it just happened suddenly. I'm the only user and its never dropped it or banged. The edges of the discoloration shake too. Its very hard to read some of the wording, and the images are all a mess! I've checked the Accessibility >Vision>Negative colors, and that's already unchecked. Might have to get a new one, but any help would be greatly appreciated!!
Was dit antwoord nuttig?
It may be that the motherboard is damaged. BUT... before you go there, check that the LCD ribbon connector isn't damaged/twisted at the connector. The ribbon connector can be disconnected at both ends, and all you need to do to access both ends is open the case, removing the three screws under the camera cover and using a pry tool to remove the back.
If you're looking at the back of your Note 10.1 with the camera at the bottom, the LCD ribbon cable is the left most cable crossing the battery and it's marked LCD.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 305
