Ga door naar hoofdinhoud
Repair guides for Dell Inspiron laptops. A line of mid-level Dell laptop computers.
1400 Vragen Bekijk alle
Why wont windows 7 boot
i have a windows 10 laptop but i want to put on windows 7 because of opedit
i put it on a bootible drive but it keeps saying cannot find drivers even after i inserted them
Is dit een goede vraag?
Score 1
4 opmerkingen
Sorry. we cant understand what you want to do.
are you going to downgrade windows 10 to windows 7 or do you want to install component used on windows 7?
door
and please tell us what Laptop you use and how you made the bottable USB-Stick (wich tool)
door
downgrade from windows 10
inspiron 14
door
it was rufus
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Have you ever thought of just using a VM and installing windows 7 on that and running it from inside windows 10
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
editing programs are best to run in a virtual environment that way if you screw up you OS you can just reload and try again VM Ware is a good and easy to use Virtual Machine
door
i would like to use the parental controls on windows bc i dont have windows 10 pro
door
is the opedit a parental control program ? I thought you were talking about OP/edit. What version of windows 10 do you have
door
Het nuttigste antwoord
Hello dave
Hope this article will help you to downgrade
Score 3
2 opmerkingen:
but i need pro to use opedit
door
What do you mean? Windows 7 professional ?
door
Hi from reading what you said it sounds like you are trying to install windows 7 onto a windows 10 PC, and that this PC has windows 10, well to use a boot media on windows 10 you will have to change the bios from UEFI to Legacy before you can boot to a media like a flash drive or DVD
2 opmerkingen:
How is that done?
door
i turned off secure boot and changed to legacy and it still didnt work
door
Voeg je antwoord toe
dave zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 104
