Ga door naar hoofdinhoud
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
241 Vragen Bekijk alle
The volume is at max and can't be decreased
seems like the volume up button always gives contact to put the sound at max. Sliding the volume down in dsi sound studio helps, but as soon as you release the slider the volume gets to max again.
Is dit een goede vraag?
Score 3
3 opmerkingen
I noticed you never got an answer to this. Are you still having this problem?
door
Did either of you get an answer to your problem or get it fixed? My sons systemis doing the same thing. Thanks.
door
Did I miss understand? I thought over on Meta it was decided to vote these into comments, not Questions. The problem has never had a accepted solution in almost 9mos. Do we want to have another Question the samet?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Your "up" volume button is stuck down; check to see if any crumbs or dirt have gotten in there. You might need to replace the SD card slot and volume control assembly.
Nintendo DSi SD Ribbon Cable Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 1
My thought would be that the slider button is off track and no longer adjusting the slide switch on the motherboard. You could take it apart to confirm this.
Voeg je antwoord toe
Joost Appelmans zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 21
Altijd: 5,371
