Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
60 Vragen Bekijk alle
Remove the original home button when replacing iPad mini screen
I'm replacing the digitiser screen on an iPad Mini. I want to retain the original home button so that the fingerprint recognition still works. I can't find a guide to removing the original home button from the digitiser panel. It seems to be glued in place with something harder/stronger than the usual double-sided tape. Is there a guide for this? It is not included in the screen replacement instructions.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Shop iPhone Fix Kits
SLA DE UPGRADE OVER
4 Antwoorden
Gekozen oplossing
Thanks for the answers Ross and Jimfixer.
I used the iFixit heat pack from the front face of the screen, just over the button area and it softened the glue enough to be able to slide a sharp knife into the glue.
Now I just need to put it all together with the new screen.
Cheers,
Andre'
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
There is a guide here on ifixit
iPad Mini 3 Wi-Fi Teardown
and it does appear that it is glued down. A hot air gun should help release it but take care not to get it too hot as it can melt solder as well. A hair dryer may work as well
Score 2
Its hot glued down you could try a hot air gun to heat the glue and soften it
Score 1
I have found that applying a small amount of heat and then lifting the hot glue part out with tweezers works well :)
Voeg je antwoord toe
AndreFix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 1,720
