Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
Vraag afgerond
The mid case is damage I can't use my thunderbolt socket
There's a ring between the upper and lower case which was damage when it was dropped on it's corner (mid ring case) not sure what it's called. Then water was leaked on the keyboard and shorted the key pad, that's easy to get and replaced it's just the mid casing part I can't name or identify to get and replace.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here's the part you need: MacBook Pro 15" Unibody (Mid 2010) Upper Case
MacBook Pro 15" Unibody (Mid 2010) Upper Case Afbeelding
Product
$49.99
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Do you sell that case?
door
Click on the link.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 73
