Ga door naar hoofdinhoud
Released November 2013. 32 GB of Flash Memory. 8GB of RAM. Quad-Core Processor. Identified by model number EGQ307. 7.58 x 4.60 x 0.45 inches. 1080 x 600. 4.5 hours battery life.
16 Vragen Bekijk alle
Why Is My Battery Not Charging?
My battery doesn't seem to be able to charge, or hold a charge. What can I do to fix this?
Is dit een goede vraag?
Score 3
3 opmerkingen:
my family received 4 of these for Christmas 2014 and this had been a problem for all of them for a few months - could all of their batteries really need replacing or is there another issue that it could be?
door
It is not the Battery. The USB charging port is cheaply made. Either you need to get a better tablet, or you can replace the port. Remove the back, pull off the black fabric tape and unscrew the screws. Lift up the tech board and you will see that the port isn't even connected, so it will be very easy to replace. All you need to do is buy a new port and replace it.
door
It is the port.
door
Voeg een opmerking toe
2 Antwoorden
If you have been having trouble with battery not holding charge and now it does not charge your battery needs to be replaced.
Was dit antwoord nuttig?
3 opmerkingen:
Here are instructions on how to replace your battery: Ematic EGQ307 Battery Replacement
door
door
Id say you have the same issue. Maybe you can claim warranty on them
door
Mine turned on for 3 weeks and nada no charge. .. Anyone else have the warranty contact information?? It'd. Be greatly appreciated
Voeg je antwoord toe
Jonathan Scinto zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 2,903
