Ga door naar hoofdinhoud
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
Vraag afgerond
Can't access my booth set up
Upon opening the asus eee pc the only thing we can see is the booth set up and it will stay there ..can't booth and can't start it..what do you think is the possible solution on this?
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Your description is incomplete. There is probably an error message reporting the problem. Maybe it is telling you that there was no bootable device found.
Did it work before? Does the BIOS detect a hard disk? Did someone format the hard disk?
If the hard disk is working, you can always reinstall any OS using a bootable USB device. You may also try to reinstall from the original recovery partition via BIOS option if it wasn't deleted from the hard disk.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 111
