Ga door naar hoofdinhoud
Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
33 Vragen Bekijk alle
USB port came loose
A few weeks ago, the USB port on my NST Glow came loose. Now, it will not charge at all. Is there any way to fix/replace it?
Is dit een goede vraag?
Score 4
3 opmerkingen:
Did anyone ever find a replacement USB socket for this device?
door
the loose port connection means I also cannot hard-wire to my computer to download library books. How can I get this fixed?!
door
Where can I buy this port connection?
door
Voeg een opmerking toe
1 Antwoord
Carter clavierkid, you will have to disassemble your Nook, here is a teardown and either solder the old port back on or try and find a replacement.
Was dit antwoord nuttig?
5 opmerkingen:
Can be quite a tricky job. Here is a video I did of soldering a similar port. It may be helpful if you are going to attempt it. https://youtu.be/gaHlbbxbTGs
door
James Soulsby, excellent video. I've been a fan of your work for years. Thank you for joining the great ifixit community.
door
I'll have to find a T5 screwdriver first. I'll go out and find one today. Thanks for the advice!
door
2 of the pins on my USB port have completely broken off. Any advice on where to find a new one?
door
The local iFix shop claims they have replacement ports for other models but not the simple touch with glowlight. Is this really such a special port?
door
Voeg je antwoord toe
Ella zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,375
