MacBook Pro screen replacement doesn't display correctly
I've tried to replace the display on my MacBook Pro (ME294ll/a) Late 2013 but the image is not displayed correctly. It looks like this:
http://i.imgur.com/J9TOewx.jpg
My brother had the same problem:
http://i.imgur.com/N9TbN2u.jpg
…but he just reconnected the ribbon cable and the screen began to work correctly. I tried several times to reconnect the ribbon cable, but to no avail.
I tried to change the connector from crashed display – it didn't help. GPU is also ok because I use external monitor right now. Replacement screen also must be suitable (model: 661-8310). I've bought a brand new.
Does anyone know what could be the problem?
Is dit een goede vraag?
Did you check for damaged or bent pins on the connector?
door Tyler Momberger
Of course but only visually. Unfortunately I do not have special equipment to check damaged pins. But... before I broken my old display, everything worked as it should.
door paulpatap
